Chicago, IL, USA
My 2020 Palisade Limited with self leveling shocks now rides extremely rough with an up and down bouncy feel over rough roads that is very, very bad in particular for rear passengers. Based on a bunch of reading of people with similar issues I expect the dealer to tell me one or both of the rear shocks is leaking / worn and needs to be replaced. The car has 67,000 miles on it. I'm wondering if any of you have recently been through this and what I can expect to face from a Hyundai dealer in terms of price... I'm just wondering what is reasonable and how high a number to expect so if it seems totally out of line I can bring it elsewhere for a second opinion vs. just getting the job done right away. It's a shame because after a little over 4 years I'm planning on selling and replacing the vehicle later this fall and I hate that I'm facing a big bill but it is what it is. Thanks!
Imperial, CA
What I Drive
Palisade 2020 Limited
#2
Hi
I’m facing the same issues with my Palisade 2020 Limited, almost same mileage like you, 63k. Did you figure it out what the problem is? And repair costs?
thanks
OP
C
Chicago, IL, USA
Thread Starter #3
I'm sorry I didn't reply sooner, I didn't see your question until now. I did end up having the dealer check it out. They stated both rear struts/shocks (rear leveling on my Limited) had to be replaced. Total cost out the door was $1860. I saw other posts on other forums quoting $1700-2200 for this and also stating the these OEM rear leveling are specific to the Hyundai Palisade with no 3rd party lower cost alternatives unlike if they had been a more conventional strut/shock. While maybe I could have found a better deal I just pulled the trigger. The fix is perfect and the ride is normal again.
JStrat
New Member
Tennessee
What I Drive
2021 Palisade
#4
Just in case anyone is searching for info on these self-leveling shocks and think that your's are blown - here is some info for you. I didn't realize it because the "decline" was so gradual, but placing two full grown women in the back during a family outing and watching them bounce around, I realized something was seriously wrong. I at first thought it was my fairly new Continental tires (10,000 miles on them), but decided it couldn't be that and starting looking into the shocks. At 70,000 miles, I am out of warranty for that work so I decided to try to tackle it myself. The self leveling shocks at the local dealer were $520 EACH and they wanted another $250 to install them (over $1,300 with taxes). I found them online at a dealer in Virginia for $399 each - but local dealer would not install them unless I bought them there. Determined to save money, I ordered them and they came in about a week later. What I thought was going to be a pretty hard job only took me about an hour (for both shocks) and I am not a great mechanic. It was super easy and if you have any mechanical experience at all, I would say give it a shot. No special tools were needed. The ride is back to "factory new". I had forgotten how nice these things ride. Now, I am a bit peeved that they were shot and that they are so freaking expensive, but it is the only thing that has gone wrong with the car in three years, so I'll live with that. One additional point...the new shocks came with a plastic seal (don't forget to add this when you do the install) and the old units did not have the seal. Hmmmm.
BooBoo
New Member
US
What I Drive
2021 Hyundai Palisade Calligraphy
#5
My “new-to-me” 2021 rides okay on smooth roads but is a bouncing battle wagon on rough roads. Certainly not the luxury ride touted in the 2021 articles on the Palisade.
Searched for the possible problem while at the dealership getting the promised repairs and landed here. Told the Service Writer the issue and what y’all had reported. He checked with the technician and told me there is a Technical Service Bulletin for the issue.
TSB 22-SS-001H
I put it in a search bar and didn’t get results to know what it says.
They’re also going to replace the rear shock/strut.
I’ll add here and try to find the original post…, the worm gear for the steering wheel is now on order thanks to this forum!!! It, too, has a Technical Service Bulletin:
WORM SHAFT TSB 22-ST-005H-1
Thanks everyone!!!
Tabz
New Member
New york
What I Drive
2020 Hyundai palisade
#6
Hi. New to the forum. After looking into the same issue with my 2020 palisade, finally took it to dealer hoping it's covered under warranty. Nope! Was expecting that, but hoping it was partially covered or something. Wishful thinking. Anyways, dealer quoted $1850 plus tax. So decided to search online, did not find any better pricing. I will have to pull the trigger.
Utah
What I Drive
#7
New to the Palisade forum. I've got a 2020 Limited. I believe my shocks (rear) are trashed. Picking back up on this thread has anyone figured out if there are any aftermarket shocks or if these can be replaced with non-self leveling ones (likely with a different spring accompaniment)? And, speaking of aftermarket parts, I can't find much of anything regarding parts for this vehicle; there are only a select few on 1AAuto, RockAuto, CarParts.com, you name it. What's the deal with parts for this thing??
JCT
New Member
Prescott Valley, AZ
What I Drive
#8
Have 2023 Palisade Calligraphy same issue. Both rear shocks are being replaced under warranty. Only 18,000 miles. Shocks are crap. Need to find an aftermarket replacement. Any thoughts?
Utah
What I Drive
#10
I found some sellers on eBay going for around $272 for a set of 2. The seller of the ones I bought in particular, ensured they were OEM, not just OEM replacements. Looking closely at the photographs, the shocks have "Mando" etched on them; this is the manufacturer that produces many of the Hyundai OEM parts, including shocks. I would love a better quality aftermarket option but, that doesn't seem possible at the moment, so better $272 and I install myself than the $1,300 installed that others on this thread were quoted. May be a few weeks until I receive the parts and it gets warm enough for my motivation to get outside and install these but I'll report back the success or lack thereof after.
JCT
New Member
Prescott Valley, AZ
What I Drive
#11
Anyone file a complaint with the NTSB? Rear shocks are the worst I have ever seen in my 70 years of life. I would bet the new model for 2026 will use an upgraded shock. What say you?
JMW
New Member
Jacksonville, Fl
What I Drive
2023 Palisade
#12
Yes, we have filed a complaint with the NTSB and currently have a case with Hyundai corporate. We have a 2023 palisade calligraphy with 40,000 miles and the left shock has been replaced a total of five times now. The right shock is at 3. Of course corporate has no answers except to take it back to the dealership to be inspected. The replacement shocks last approximately 1000 miles and then they start squeaking and rattling around. This is with us driving the car on eggshells trying to dodge every little bump and pothole. The dealership will replace them under warranty as they are always leaking. I would like to know why these self leveling shocks aren’t not under a recall by Hyundai.
JCT
New Member
Prescott Valley, AZ
What I Drive
#13
We have been through 2 sets of rear shocks in 20,000 miles. Done with the dealership. Waiting for an aftermarket shocks for a reliable company. Gabriel is looking into making an OEM shocks and KYB should be in production soon.
WRuiz101
New Member
Maryland
What I Drive
2023 Palisade
#14
KYB sells rear w/o auto leveling shock. Model# 3440217
No self-leveling...for now.
